Hey Guys
I've got a small problem with my Attesa. The code is 21 which indicates it's either the Throttle Sensor or the Circuit. I checked the manual and it is on page CH74. Problem is that I'm having trouble reading the page, the numbers of the control unit terminals that I need to check are blurry.
The first check to see if the control unit is faulty is to use a volt meter and check terminal 47(+) and 48(-) I believe.
If I determine that the Control unit is not faulty I need to check the voltage between terminal numbers 50 and I think 30. Not sure which is supposed to be + and which is -. Also, I'm not entirely sure it says 30... could be 38 or 39.
Anyone have a better copy of the manual than the one on McFly's page? Or knows for sure which terminals I have to check.
Thanks.
Thanks.
