Well I just thought I will let you know. I bought a aluminum drive shaft and I waited to install it as my car is a project and it did not need to be installed untill i had the clutch to go with it. When i finaly got around to the install, it vibrated really bad at speed. I took it to a coastal powertrain to check it for balance and when they inspected it. It was way out of spec where the slip joint is and was machined very poorly. Eg. male/female. and did not contain any grease in the joint. I contacted DSS and was informed that their was only a one year warrenty and I was not covered.
So watch out they sell defective products and do not stand behind them.
800 down the drain
800 down the drain
