GTR front struts interchangable with Z32 or gtst or anyothers?
  • GTR front struts interchangable with Z32 or gtst or anyothers?
    Hi, did a search but didn't find a clear answer, Im woundering if R32 gtr FRONT struts/springs combo is interchangable with GTSts or 300s?
    TTBB is a true ACN member
    If they are interchangeable, but stock GTR combo is a little shorter than the stock ones used in GTS.
      anybody else?
        Sorry, I meant to say "Yes, they are interchangeable, ..."
          No they're not. Gtst ant gtr are different. Bottom mounting points are different style. Gtst and 300zx are the same.
            If you are thinking about the rear mounting points, the GTs-t is different from Z32 and GTR. For the fronts they all share the same style, as I did put a set of GTs-t front onto a GTR last year.
              im pretty sure fronts are the same....rears are different. gtr and gts4 mate up in the rear?
              They are few inovators, but many followers....
                Thank you guys!
                  yup yup hope all the info helped you out!
