hey i have a few random questions. im swapping my motor into a GTS so thats why some of them are retarded.
1. my timing belt tensioner the spring behind it is not hitting that little knob the sticks out, im not sure if it matters, my timing belt is tight just not sure if that spring is supposed to rest on that post to serve a purpose.
2. i see people talking about boost restrictors all the time and its starting to worry me, if i plumb the turbo wastegates to a vacuum source will it serve the same purpose or do i need these restrictors.
3. injector resistor pack, do i need this? or since its a rb26 i wont need this?
4. are all rb clutches interchangable? if i were to get a mild clutch fdesgined for an rb20 that can hold 500hp will i be able to use it with the 26 flywheel? reson being is i want a better clutch but dont want to pay close to a grande for a clutch.
5. for my apexi avcr boost controller if i were to run a switch would i be able to monitor both injector duty and rpm?
thanks
thanks
