Hey,
I have a 91 R32 GT-R and Iam having a weird issue with it. The car pulls pretty hard under low RPM. Anywhere from 0-3500ish, its perfect. After that, it has trouble getting to 5000. At first I thought it was a boost leak but I had someone look at it and said there was no visible leaks and everything seems to be alright. He said it might be the mafs. After driving it himself, he this its starving for air at high RPM's and think its the mafs. I took it out for a spin after and i have major trouble getting upto and over 140, in high rpm range. On the 401 I had trouble getting to 120 in 5th.
Any recommendations on what it could be other then the mafs?
IF it is the mafs (kinda hoping it is, semi-easy fix) I want to upgrade to the Z32 ones. Is there any special modifications or adapters I need to do make the Z32 mafs work?
thanks
thanks
