Originally posted by aN4rk1
View Post
Possible Maf problem, need help diagnosing
So I did some poking around with my other mechanic and we retarded the timing and it seemed to pull a little better. What we think is happening now is that when we did the waterpump and timing belt change, the timing on the crank might have been a little messed. The two cams seem to be absolutely perfect, as we did a quick check yesturday, but we didnt check the crank as we didnt have enough time. We are going to rip it all apart next weekend and see what she says.
Originally posted by Marus92 View PostOr the plugs, bad tips getting snuffed by boost. Should get a misfire code for bad spark, right?
Edit: Stock boost plateaus near 5500RPM...
Originally posted by TW View Postdoesnt sound like a maf issue to me.. sounds more like plugs/coils to me. did you test your coils? check for fouled plugs? gap plugs properly?Last edited by aN4rk1; 07-16-2010, 01:12 PM.1991 Silver Skyline R32 GT-R - SOLD You will be sorely missed girl :'(
You can test the coils by testing the resistance in the coils. Use a multimeter and touch the leads on the outmost pins on the coilpack connector, if I recall correctly. You need to disconnect the coil pack harness from each coil to get at the pins. You are looking for 0.6-0.9ohms. Don't forget to touch the leads to one another to get the resistance in the multimeter and subtract that from the value you get from the coils.test each coil.
To gap your plugs, you need a feeler gauge. You can get on at caca tire. You want to make sure the gap between the tip of the plug and the metal piece is 0.8mm. Pull each plug and check for carbon fouling.
Have you checked for boost leaks as well?
Well i finally got around to doing an ECu test. Threw code 55 which is the code for all is good.
Originally posted by TW View PostYou can test the coils by testing the resistance in the coils. Use a multimeter and touch the leads on the outmost pins on the coilpack connector, if I recall correctly. You need to disconnect the coil pack harness from each coil to get at the pins. You are looking for 0.6-0.9ohms. Don't forget to touch the leads to one another to get the resistance in the multimeter and subtract that from the value you get from the coils.test each coil.
This is all pointing to the fact something might have been wrong with the car when I did the waterpump and timing belt change. I am planning to rip the front off again and check the timing. I retarded a timing a bit and test drove, and then a bit more and drove again. The car seemed to pull better each time I retarded the timing. Hopefully i can get this fixed.1991 Silver Skyline R32 GT-R - SOLD You will be sorely missed girl :'(
Just to add, did you consider that maybe it was your wastegate that was stuck open? The turbos start surging at 3000ish RPM, so if your valve is weak or there's problems with the actuation you could be just getting atmospheric pressure past the initial surge.
Go to the EN-350 page in the RB26 manual. You can troubleshoot your wastegate from there.1992 BNR32 SKYLINE GTR
Originally posted by Ben @ JNS Imports View PostIs your idle wandering at all?
Does it misfire when your losing power or still reving smooth?
I would pull out your plugs and see what color they are Also see what your boost gauge is reading at idle and at full boost and report back
Originally posted by Marus92 View PostJust to add, did you consider that maybe it was your wastegate that was stuck open? The turbos start surging at 3000ish RPM, so if your valve is weak or there's problems with the actuation you could be just getting atmospheric pressure past the initial surge.
I checked the timing again today. It seemed as though the crank was off about 2 teeth. We fixed it all up and put her back together and tried again. She seems to do the same thing but now its about 7k, instead of the 5.5ish-k as before. So its a little better. Iam going to take it to a Nissan specialist I know and get the timing PERFECT, then we can rule that out I think. It did the 7k on city streets, but wheN I got back on the highway, it seemed as though it was at 5.5k again, that seems like an airflow issue, which again...points to mafs. What I think I want to do is ask around and see if I can borrow someones PROPERLY working mafs and see if that fixes it, if not then I check the coils/plugs, then wastegate, then...1991 Silver Skyline R32 GT-R - SOLD You will be sorely missed girl :'(
Originally posted by Marus92 View PostGood luck man!
Btw did you say 7k RPM on the street? You're really running her huh? Stock oil pump?
And thanks, ill keep posting.1991 Silver Skyline R32 GT-R - SOLD You will be sorely missed girl :'(
Originally posted by Ben @ JNS Imports View PostIf it's not miss firing while losing power you can pretty much rule out plugs, coils, ect. 3.5-4 on the stock gauge is too low. Should be around 7 I believe
I need a copilot1992 BNR32 SKYLINE GTR
Originally posted by Marus92 View Post7mmHg is 14.7psi or 1 atmosphere...isn't stock R32 boost 8psi? Can't find the source I found back when I was checking for it. My GTR is stock but I dont look at the boost gauge when I accelarate.
I need a copilot
Another question. My Ecu still has factory Japanese tune. I plan to get it tuned at some point next year ($$ issues) but in the mean time, what should I gap my plugs to? and what king of plugs? I am using BKR7E's right now which I was told were the best plugs. If it is my coils, I will be getting some YellowJackets and I want the best Coil + plug + gap combo for my car with Factory ECU tune.1991 Silver Skyline R32 GT-R - SOLD You will be sorely missed girl :'(
Yeah everyone seems to claim 14 psi with the restricter removed. I thought even with the restricter it was a bit higher than 8 but your probably right. I haven't even driven a gtr with one. Anyways if you pull your plugs and inspect them it should give you a good indication of whats going on in the cylinders. Your problem probably lies in your fuel or air being off at WOT. I'm assuming you checked your ignition timing via timing light afterward?
Originally posted by Ben @ JNS Imports View PostYour problem probably lies in your fuel or air being off at WOT. I'm assuming you checked your ignition timing via timing light afterward?
I have not done this yet, Iam trying to schedule an appointment with a specialist.1991 Silver Skyline R32 GT-R - SOLD You will be sorely missed girl :'(
