my car is running on only 5 cylinders. #3 injector is not functioning. I swapped coilpacks and it stayed at #3. I've swapped injectors and it stays at #3. I tested the voltage at the plug and it was almost nothing, 0.12 or 0.13. tested #2 plug and it was 13.5. I have no idea what to do now. anyone have an idea?
no voltage at injector
try checking the ground, use your multimeater on a good positive source, then check the ground, you may have a corrosion issue, the power on #1-3 is a common source, thats why i mention to check your ground, if you have power at 1 and 2 you should have it at 3.Owning a turboed car is a great way to prevent your jackstands from getting stolen
