Another problem with the car
I was driving, dropping my friend off and once I pulled into her driveway my clutch pedal went right to the ground as I put the car in neutral. It went stiff again for a sec when I put it in reverse but when I wanted to put the car in 1st the clutch went to the ground and didnt come back up and could not get into first. I finally got the car home by putting the car in 2nd and starting trying to make it turn over and just drive straight home. I got home and looked under the car and there was grey sparely fluid on the ground. I put some dot 4 brake fluid in the car and had a friend pump the clutch and it completely drained right out under the bell housing. Is this the slave cylinder or something else? And if its the slave is it located under the driver side on the right of the tranny? Is it push or pull type? Sorry Im still learning part names.
Any help would be great! Pics if you can!
