Whats up guys. 1st I have to thank every1, Ive learnt so much from this forum in the last few months. And now its time for me to ask those last few question I havnt found.
1st off my car isnt a real GTR but it has the rb26 swapped into it and my questions are all engine related so I figured this would be best spot. Its a 91 GTS-t sedan. The guy that built the car in Japan was obviously a genius and really knew what he was doing. He build this thing from the ground for the track and it seems to be very very well done. The car is a beast and pulls like crazy. But being a 1 off build its kinda hard to figure everything out. Im hoping you guys can help.
1 quick pic of the car than well start Q&A.
Alright, Im gonna try do this easy as possible for all of us. Ive took a pic of my engine, # the questions I have and labeled the engine. Here we go...
#1
I assume this is for my boost controller. This is the 1st thing I noticed... I dont have 1, but it did. Its plumbed for a closed system but in a way Ive never seen before and cant find anything like it... would this be right.
The blue line runs along under the intake manifold and goes into the back underside of it.
I assume this is right but Ive never seen it hooked back into there. But from what it all looks like I just need to buy a new 3way controller and plug er in???
#2
This is another weird 1. Most RB26 I see have these 2 plugs hooked together side by side. Mine has another 8pin connection running under the washer jug. 1 wire spliced into the other 8pin.
Leads down there to this...
It says JECS 015-000J03 on it. After googling Ive found its a Injector Resistor Pack. Any1 know why mine would have this?
#3
There 2 wires there, a brown and a black cut and taped off. Are these for the boost controller?
They plug into here...
#4
Theres 2 sets of plugs here. Both siliconed up. Any1 know what these are for and why they would be siliconed?
Close up.
#5
These 2 plugs have always been unplugged. Since the car is running great I assume these are also right but why??!?!
Close up... They go together.
#6
The bottom brown plug has nothing. Whats supposed to go there?
#7
This tube here is broke and plugged with a screw. Where is this supposed to lead too?
The other end leads to here... End with cable tie.
#8
The final question for now. What is the tube with the bolt in it? Some type of drain?
Huge thanks for the help guys. I want to understand every aspect of this car. Im not the type to have some1 else work on my car. Hopefully this thread will help a few others like me in the future.
#1
#2
#3
#4
Close up.
#5
#6
#7
#8
