what is the max boost on stock injectors....18-19 psi...just to know ,because it will take a bite of timel before i have my 750cc
max boost on 444cc injectors
KAD paint
FMIC
HKS bov & piping
TWIN 3in DOWN PIPE
FREE CAT
4in CATBACK
STAGE 4 CLUTCH ( 6 puck )
N1 OIL PUMP
STEEL WHEEL TURBOS
N1 RODS
WISECO 87 MM FORGED PISTONS
ACL MAIN & ROD BEARINGS ( std )
COMETIC HEAD & BUTTOM END
SIEMENS 750CC INJECTORS
WALBRO 255
12.3 @ 112MPHTags: None
You have N1 turbos, but your limitations are your stock injectors. 444cc=444hp. But a general rule of thumb, you don't want to go at 100% duty cycle on your stock injectors, so 85-90% is what is consider a safe good level which in turns get you about 400ish hp. Unless you have adjustable fpr,you can increase the fuel pressure to get more hp to the stock injectors. But, that's a whole other story.
set at 16psi for now....pulling good1989 SKYLINE GTR
KAD paint
FMIC
HKS bov & piping
TWIN 3in DOWN PIPE
FREE CAT
4in CATBACK
N1 OIL PUMP
STEEL WHEEL TURBOS
N1 RODS
WALBRO 255
12.3 @ 112MPH
