All taken care of. Thanks!
Surging Woes/Adjusting Throttle/Capping Recirc.
1990 Nissan Skyline GTR Nismo Edition - Action Hotdog Go!
2008 Audi RS4 - Hand Banana
1998 Subaru Legacy 2.5GT- Dirty Winter Car
1988 Toyota Supra Base - Trojan Judas Hairnet Battle Tree.Tags: None
to cap it all u need is a 2" aluminum or whatever u can find atleast 1" long andthen clamp it but use the exusting hoses...know i mean if u cant find a cap thats big enough...
check for vac leak plus re adjust ur tps n normally if u clean the aac or iacv u get high idle after...Toy: BNR32
DD: R50
Injector cushions? And I don't think it's a leak between head and manifold. I torqued it all down and used new gaskets. So you just turn the two nuts to lengthen or shorten the cable?Originally posted by love_boost View Postits hard to say but it can be your injector cushions, or maybe there is a leak in between your head and intake manifold. to adjust the throttle cable you just have to turn the 2 nuts on the cable itself.
I can't get it to idle at all. Idles fine for a bit, then drops, then stalls.Originally posted by markc32 View Postto cap it all u need is a 2" aluminum or whatever u can find atleast 1" long andthen clamp it but use the exusting hoses...know i mean if u cant find a cap thats big enough...
check for vac leak plus re adjust ur tps n normally if u clean the aac or iacv u get high idle after...Last edited by NerdJuice; 09-12-2010, 02:16 PM.My Garage:
the o rings at the bottom of the injectors they are thick rubber washers, if those twist when you put the injectors in you will get a vac leak from that.
if your gasket on the iacv is wrecked it will make a bad seal and leak pretty horrible.Last edited by love_boost; 09-12-2010, 05:00 PM.
Ah I gotcha. Okay well it looks like it could be any multitude of things. Early winter parking for skyline!Originally posted by love_boost View Postthe o rings at the bottom of the injectors they are thick rubber washers, if those twist when you put the injectors in you will get a vac leak from that.
I'd still like to get the throttle sorted out. How can you lengthen/shorten the throttle arm things?Last edited by NerdJuice; 09-12-2010, 05:30 PM.My Garage:
