I think if you are keeping it a DD you will want to have ac at some point in the summer. You should buy a used set from someone parting out their ac. (Like me lol) Iv never heard of a ac compressor seizing before. Did they mention how it might of got seized? Did ac work when you got the car?
Burnt Rubber Smell in Cabin Followed by Engine Failure
AC compressors will seize easily if someone put the wrong refrigerant in the system. If you put R134a (pretty much all you can get, at least here in the states) in a R12 system (our cars) it will work for a while and eventually seize. This could also happen if someone did a R134a "conversion" on your R12 system and didn't do it properly, i.e. not evacuating the old stuff out or not adding the right amount of lubricants. Might not be cause of your problem, but I've had it happen to me.
Originally posted by needavdub View PostAC compressors will seize easily if someone put the wrong refrigerant in the system. If you put R134a (pretty much all you can get, at least here in the states) in a R12 system (our cars) it will work for a while and eventually seize. This could also happen if someone did a R134a "conversion" on your R12 system and didn't do it properly, i.e. not evacuating the old stuff out or not adding the right amount of lubricants. Might not be cause of your problem, but I've had it happen to me.
yea no worries louis... was just gonna say i know a few people who are selling AC pumps as well.. i would think something near $100 would be fair for something like that.. as for time to install it, its easy as hell to do yourself, if u wanted.. heres how:
1) discharge completely your AC system... the gas in the system is free-on, there should be like a nipple somewhere on one of the hard pipes near the rad, when u press it in, u hear hissing... thats the gas... you need to get that removed into a special container (they sell the containers at most parts stores nappa or canadian tire)
once the gase is out of the system...
2) loosen the tensioner pulley and remove the belt from under the car (urs is gone alrdy lol)
3) 2 bolts below and 2 from above for the pump itself, thats how it attaches to the bracket on the engine
4) 2 electrical connectors to un plug.
then it should be just hanging down with the gas tubes attached.
5) remove the bolts for the tubes... and they should come right off...
installation is the exact reverse order... 5,4,3,2,1... done. ... maybe an hour or more. worth trying yourself first though, heres a photo of what your looking at so you can see what im talking about:
yea, franks got an AC pump too for sale here in MTL.. he's asking "offers" but if sarazinj is giving his free, just pay shipping, install it yourself, and your good to go bud!...
people always think things are worse then they actually are when something goes wrong with these cars... truth is, most of the time a simple post for help on the forum will answer a lot of questions and aleviate a lot of stress...
keep us updated on how it goes.
P.S. I assume since your location is CFB borden, your in the forces... Thanks for doing a job that no one else can do. have a good freind of mine on his third tour of duty in the Ghan right now... best of luck to all .Last edited by archaeic_bloke; 01-08-2011, 05:46 AM.The SkyLife Community & News Website --> http://www.skylife4ever.com
