Hey guys, I am going to be taking my rb26 out of my r32. The motor is in perfect condition but I am going to be putting an already fully built one in. Can you guys give me some tips and pointers on removing and putting them back in. Problems you came across, tricks, tips. Everything helps! Thanks alot in advance guys. Oh and YES i am a newb with the rb's
Rb26 Removal
Thanks! lol always appreciate when people find the info useful, but yea, have a look through my site that he posted, its pretty much a step by step of every connector/hose on removing, if you look on the side under the "how-to" at the right of the web page, with in the first 4 links you'll find, "removing the RB26" and then "re-installing the RB26"Originally posted by NeptuneGTR View Post
feel free to PM me if anything is unclear so that I can update it and clarify it for future readers! best of luck and post some pics in the build section! we'd all love to see your new motor and your work!The SkyLife Community & News Website --> http://www.skylife4ever.com
exactly what i followed when pulling my motor and i was a newb!!! very helpful only thing i would change is if at all possible get on a lift and drop the motor/subframe out the bottom rather than trying to pull the motor/tranny out through the top. but yea thanks josh his website is dope!Originally posted by NeptuneGTR View Post1991 Nissan Skyline R32 GT-R: 710whp 521 ft/lbs 27.5psi 11.8 @126mph low boost
Thats more work anyways. I only heard that was an easier way with the Z32 300ZX.Originally posted by gtrjon View Postexactly what i followed when pulling my motor and i was a newb!!! very helpful only thing i would change is if at all possible get on a lift and drop the motor/subframe out the bottom rather than trying to pull the motor/tranny out through the top. but yea thanks josh his website is dope!
I've pulled from the bottom on R32 and S13 before and I dont do it that way anymore. Mostly because of the steering rack lines and shaft are a pain.
I was surprised with that write up that your hoist could go high enough with that rigging system. Mine doesnt
. must have it on the 1/2 ton mark (out all the way). I use one of those princess auto adjustable tilt systems and they work quite well. Toss it on the hoist hook and then usually use a couple seatbelts to tie it to the back of the mani and the P/S mount to pump bolt. If you use chains, be careful to unplug the TPS as a lot of guys bust that easy. Also, having a long pry bar or crow bar helps with getting the front diff off the hicas pump and lines. More so when putting it back in. other than that, I think Nissan did a good job for a design point. Eng and trans comes right out and back in pretty easy.
when you use the Princess auto adg tilt puller, I strap the extra seatbelt to the back of the mani to the rear loop to heep it more toward the rear of the engine. using this makes it so i dont have to get under the car with a jack as I can adjust the tilt from the top all on my own. usually takes me 15 min to pull out on my own including hook up. Another 5-10 to get it back in. I think ive pulled these things in every way possible as Ive literally done like 50. this way is my personal stress free way. Even with people watching, drinking beer and not helping, its pretty easy
haha
I also got a bung fitting for the rear awd attachment on the back of the trans. i use a pipe wrench to get the line off and quickly toss in the fitting. Less mess this way and i can save the fluid in the trans (if its good of course).
one more thing to add. I keep a small 5" piece of a 2X2 piece of wood cut from a 2X4. i use this behind the engine. After the heater lines are off and out of the way, the wood block fits behind the head between the head and firewall. This way, when I jack up the trans, remove the trans crossmember, I can lower the trans and the engine doesnt sag. Jack doesnt go back under the car till i install the cross member. Never damaged anything ever in case you guys were wondering. It works quite simply
ALLEN PETERSEN
Number (604) 961-2449
RB30`s for sale!
right on thanks guys and thanks josh that site is what i will be refering to when i will be doing it. I got the 2 ton engine lift from p auto tonight, and my old man said I can use his garage in a month when the weather warms up a bit, which should give me time to get all my stuff togetehr. Thanks again anything else is always helpful
engine install and removal is simple and smooth if you know the steps. get lots of info first. you're on the right track.
took me about 3.5-4 hours alone to remove. and the same to install alone.
if you have any specific questions, feel free to pm me or post here and ask me. as ive done it quite a few times.Last edited by Bugsly17; 02-19-2011, 03:42 PM.GTRC-OG
