Originally posted by Marke
View Post
http://www.hksusa.com/products/?id=1506
and this kit is definitely a named brand EMIC (Ebay made in China) product.
As your car gets older there will be issues with corrosion on the wiring so even if you have a good ground your problem may be at the voltage supply end. Just like cleaning the battery terminals whenever I work or replace something electrical (starter, alternator) I would take some some sand paper and clean both the supply and ground wire connections.
