hello i have an r32 gtr and i hear a constant hum when i drive and it stays the same from 1 kmh up to whatever speed i go meaning it doesn't get any louder i thought it was my tires but i just had them changed also when i turn the car off while driving in nuetral and let it roll the noise stays, i just found out i have a torn cv boot on the front driverside drive axle so i don't know know if it's the wheel bearing or the axle any info would be helpful thankyou
noise problem help
Sounds like a wheel bearing to me, take a stethoscope and with the car jacked up on all 4 rotate each wheel individually, and listen at the hub with the stethoscope, one will sound different, thats the broken one.Originally posted by bakerman1978 View Postjust to add to this the noise doesn't change when i turn and there is very little vibration if any
usually though with bearing noise the sound gets louder as you increase your speed, does this happen?
it could also be related to the CV joint on the axle, if that's torn as you said, the grease probably drained out and now its full of sand instead of grease.The SkyLife Community & News Website --> http://www.skylife4ever.com
If you can make it to Montreal, any of the 12 JDM engine shops usually have STACKS of hundreds of Axles with good CV joints.
If you can't then it'll be either by posting a WTB ad on the forum, or worst case you have to buy over seas, msg Adam from Feast Auto, he can usually find stuff like that pretty quick and fairly priced. same goes for wheel bearings. good luck, let us know how it turns out.
and trickey, I don't know what kind of car you have, but post up a picture of your "confuckulator"... i bet its all kinds of messed up lolThe SkyLife Community & News Website --> http://www.skylife4ever.com
Moosknuckle!!! LOL!!!! Holy Core!!!
as for JDM shops in MTL, I happen to keep a database... so i'll post it here for u:
Company name Phone # address
japan motor import 514-369-3330 4255 met east provencher
Osaka jdm motors 514-382-4333 8155 langelier
Jdm advance motor import 1-866-492-1527 8105 lafrenaie
JDM Racing Motors 514-327-3231 6600 Rue Magloire
Japan Domestic Motors 514-322-4449 8250 Rue Du Creusot
Tokyo motor import 1-866-322-5558 8210 rue creusot
Japan general motor 514-321-2555 8880 champ d'eau
Nagano japanese 514-329-0001 8395 champ d'eau
Jdm auto depot 514-329-1212 10785 Avenue Racette
Jdm nagoya auto parts 514-328-0909 10570 ave ethier
Royal japanese motors 514-324-5780 10758 salk ave.
Sunrise jdm motors 514-324-6444 4610 rue forest
JDM Montreal 514-325-1777 10501 Drapeau Ave
JDM Engine Land 514-325-0888 5734 Boulevard Industriel
These guys are 100% bargainable, it's like when you go to dominican, never accept the first price they tell you.
good luck!The SkyLife Community & News Website --> http://www.skylife4ever.com
