Guys, I need a hand with an overheating issue I'm having.
set up:
rb26
new rad cap (13psi)
koyo rad
dual puller fans, on all the time
tried a couple different thermostats
n1 pump
no ac or heater core (bypassed it for testing)
stock oil cooler
50/50ish mix
symptoms:
boiling over approx 5-10 minutes after reaching operating temp
high oil temps (110+, stock gauge though)
lower rad hose stays colder than i think it should be. almost completely cold.
tried so far:
-flushed and drained system - looked good and clean
-pulled rad and flushed it with the garden hose, pretty positive theres no blockages
-replaced rad cap and thermostat
-bled/burped the crap out of it many times with the 'coke bottle on the rad' method. i'm pretty confident in my bleeding, but air in the system is still an outside possibilty
-pressure tested system to 15psi
other thoughts:
I'm not 100% positive I have good water pump flow. The only test I've done is to look for flow in the rad cap hole as the system comes up to temp. i'm just not sure what's normal. Are there any other good tests to measure pump output? It spins freely and doesn't leak...Is it common to damage the wheel/blades on the inside? I tried running with no thermostat with hopes of seeing flow easier, but didn't really help. i'm thinking about pulling the pump next
i haven't ruled out headgasket, but it seems unlikely as i'm not getting the usual systems like mixing oil and coolant, poor running, lots of bubbles in the coolant, white smoke, etc. i haven't done a leak down test yet.
Could high oil temps be a cause? I assume its just an effect.
thanks!
i have seen that before too . Mouse carcass is very bad for coolant flow...
