I just bought one used and just want to know about the throw out bearing. Can I use my stock one or do I need a special one for a twin plate clutch? I wanted get a new one but when searching found oem ones and also ones for aftermarket twin plate clutches. Not really sure what one to get.
Anyone running a Nismo Gmax twin plate?
You should always use the throw out bearings that are supplied with the clutch. They are given for a reason (usually the fit is different). That being said, the seller should be able to send you the bearing he still has. Contact him and you should be ok.No build thread.
1991 nissan
El terror
check the splines first ... i know some of the gmax ones are different then your normal gtr transmission spline because they are for an upgraded input shaft. it could be for the regular input shaft but i would be getting a clutch alignment tool and making sure the splines line up before i do anything else. heck i would roll down to nissan and ask to borrow one for 10seconds.1970 Ford Mustang Fastback -> Fully Restored with Built 351W Motor
1993 Audi S4 -> 2.2L Turbo at 22psi with a few extra go goodies
1992 Nissan Skyline GTR -> RB31.5/26 Being Built Now
1994 Audi S4 -> Fully Restored and Tastefully Modded, 2.2L Turbo with Hybrid Turbo GT3071/K26 at 25psi
I have the tool with the clutch and it came off a gtr but not sure if his had a upgraded input shaft. He said he used the stock bearing but he wasen't sure if it's stock or not. He said the clutch came with his car but he didn't like how stiff it was.
