So just want some input here.
Just got my tomei M7655 kit and had a good read of the instructions, not the easiest to understand but i have a few questions.
The install guide instructs the removal of the water outlet on the block that has 2 outlets (one to each turbo) and replaces it with 1 fitting to run 1 line.
From what I can make out , it converts the coolant distribution from the block into the rear turbo , out and then directly into the front turbo before sending it out to the regular line route for return.
I don't mean to question Tomei's wisdom on this but isn't it bad for the front turbo to be fed hot coolant from the rear turbo ? surely the original individual feed for each turbo would seem more sensible.
Of course i may be wrong , it's been a long week , but check the pdf on tomeis website out and see what you think if you have a few minutes , i'd appreciate it![Smile](http://forums.gtrcanada.com/core/images/smilies/smile.png)
http://www.tomei-p.co.jp/manuals/pdf/arms_rb26.pdf
Cheers
Cheers
