Hi guys. I've been on the board for a while and generally lurk around and find what I need. I an in the process of installing an aftermarket fuel pump as well as FPR, rail, and larger injectors. Ive read the sticky http://forums.gtrcanada.com/gt-r-tec...stall-diy.html but there was no mention of upgrading lines, etc.
Based on the aforementioned upgrade, have any of you upgraded your lines, i.e., feed and return? Is is needed? The reason I as is because based on http://www.centuryperformance.com/fu...e-spg-140.html (second section down) my feed and return lines are undersized for the HP level I am trying to acheive (425-450ish range).
Anyone able to give a little input?
Thanks in advance.
Thanks in advance.
