Hey everyone. I'm looking for some information. I am curious what people are doing for their head? I would like to build a head capable of revving to 8500rpm safely. I hope to have 2860-5s and poncams. Would it really be necessary to build the head? What do you recommend?
Building a reliable Head
quick answer... valve springs.
long answer.
old saying, "build the head for power and build the bottom end for strength"
I'm assuming you want = or < 600hp because you stated -5.
stock head with "drop-in" cams, cam pulleys and valve springs can make that power. and do it below 8000rpm.
if your head is worn out, there's no shame in rebuilding it to stock specs.
if you're doing competition or really feel the need for head work.
most important and effective modifications include port, bowl, and combustion chamber. more aggressive cams are also needed to see the benefits. something around 10mm lift is pretty good. this requires machining the head for high lift cam clearance. some companies make cams with smaller base circle for a no machining install. but those cams require aftermaket tappets ($$). stock tappet are fine so it's cheaper just to buy normal high lift cams and machine the head while it's being rebuilt. alots of research and/or a pro head builder with experience in RB's is required to balance the work. you don't want to have huge ports with small cams or vice versa.
this might help...
valve spring test:
Poncam:
Reimax street:
純正タービンからN-1やGT-SSタービンまで、幅広くカバー。材質は、純正品と違い、ねじれや曲がりに強く、レースでも使われているモノと同じです。このカムはなんと!REINIKのGr.Aのカムシャフトを設計した方が設計したカムシャフトです。
Group A cams:
