Ok guys, I've been reading and working, and spending money, and working, and reading, and spending more money and I still can't fix this damn car. At the beginning of the summer I was having the notorious RB hesitation/misfire under boost at WOT. After doing the checklist found in the "fix your hesitation" thread I determined I needed to upgrade my coil packs. I installed a set of brand new Yellow Jackets and the car ran excellent, 16psi of boost and it pulled HARD to redline. It ran like that for about a month, then one day it started messing up. I did a 2nd gear pull and it started popping/misfiring like crazy, I turned my boost controller off (takes it to 10psi) and it at least ran ok-ish. But it still had a tendency to "chug" and miss at higher RPM. Seeing how it was a sudden change I figured something failed, so I replaced the fuel pump with a Denso 290lph unit that I "hotwired" for 14.4v all the time, replaced the fuel filter, cleaned and resoldered the MAF's. The problem still persisted. My coil pack harness was in very poor condition so I thought maybe that was my problem, so last night I installed a brand new one, along with new plugs. Still no luck, I checked my TPS voltage and it seemed to be off a bit, 3.3v at WOT, I adjusted it to 4.2 at WOT and .4 fully closed. I've checked for vacuum leaks, none seem to be present. The only thing I can figure now is a fueling problem (maybe fpr), when I did a hard pull with the boost controller set at 15psi last night it started "popping" and missing and my AFR's were lean at 13:1.
I'm really running out of ideas here guys... Please help me.
