THE CAR IS FIXED!!!!!!!!!!!!!!!!!!!!!!!!!
After a couple thousand dollars and close to 100 hours of aggravation the miss is entirely gone. As speedfreak suggested I had a bad brand new Yellow Jacket coil. I bought a new one from performancewise a while ago (they were mega helpful btw, and offered to warranty the bad coil, I was just very pressed for time remodeling my house so I decided to just buy a spare. I highly recommend performancewise if you need anything). I played musical chairs with the new coil, swapping one at a time with the new one. And when I swapped cylinder #5 the miss disappeared! The bad coil looked 100% fine (it was practically new) so I'm not really sure what failed in it, but either way I'm happy. The car pulls like a freight train to redline now, much faster than it's ever been with the new 550cc injectors, bigger pump and tuned ECU. In a way I'm a little happy I had this problem because it led me to fix a LOT of little problems on the way to figuring out the big problem.
good to hear you fixed it. Good to check even brand new parts. Nothing is guaranteed just cause its new I guess
