so for the past couple days ive been having a boost issue. i washed my engine bay the other day and ever since ive been boosting fine for a bit of driving but then after a while my car will only boost to the line right before +7 (stock boost gauge) and then i turn my car off and let it sit for a bit and it boost all the way up to +7 again and then back down to lets say +3.5. is there such thing as a boost limp mode or is my? or did i mess something up when i washed the engine bay and is now restricting my boost? its using both turbos even when its being restricted it just wont get to full boost. solenoid maybe?
boost issue
Wastegate actuators sticking maybe? I dont think washing youre engine would be the cause because the issue is reoccuring sporatically. Its not in limp mode either. Limp mode restricts your rpm, not your boost.I canz take this corner at 195k cause i gots AWDZ. Get real.
I'd say either you have a leak (BOV starts leaking when it reaches a certain pressure, wastegates, etc.) or the ECU is pulling boost aka switching to boost knock maps if you're running the stock solenoid.R32 GTR FULL SERVICE MANUAL DOWNLOAD:
i washed my engine bay and after that i ran on 5 cylinders i guess because im missing one of the center plate screws and water must have gotten in. im thinking that threw a code and is putting my boost into limp mode. how do you by pass the solenoidDRIVE FOR THE LOVE
1995 NISSAN SKYLINE GT-R R33 V-SPEC GOHAN
Don't bypass the boost control solenoid, fix the problem (find and replace faulty coilpack). If running on 5 cylinders, stock ECU is probably picking it up as knock (high knock count) and switching to knock maps (knock ignition map, knock fuel map, knock boost duty) to protect engine.Last edited by Skym; 10-25-2011, 10:46 AM.RESPONSE MONSTER
it misfired for maybe 2 mins not long at all just till the water dried up. it runs perfect now. untill it cuts boost how long does it take for the ecu to clear it self of the issue or can i go in and clear it myself after i bring up the code (if there is one)DRIVE FOR THE LOVE
