So I have been trying to figure out what would cause my idle to sound like it has bigger cams which it doesn't. I have to idle the idle to about 1200rpm just so it's not loosening every bolt on my car. When cold it idles around 1000rpm and is really rough, when warm it's better but still does it and the idle is steady at 1200rpm.
I recorded a few videos today on my normal ride to work, cold start, semi-warm and fully warmed at work.
This is first thing in the morning
This one is just getting to my coffee place wit the car semi-warm
This is coming out with my coffee and you can hear how ruff it is
Here is just sitting in the car and holding the camera steady, you can see how much the car is shaking
Any finally at work(about a 10 min drive on the highway). It's not as bad but still sounds like a v8 and most people think it sounds cool, I would to if I had cams and was suppose to idle like this but I don't and it's driving me nuts.
I have replaced both o2 sensors
spark plugs gapped from 0.6mm to 1.1mm and not difference at any gap
replaced all coils
replaced all injectors
tps is set to 0.45v
maps are cleaned and re-soldered
intake system was pressurized to 10psi and one vacuum line was fixed
checked for codes, code 55(normal)
CAS is set to the middle of its range(still looking for a timing light)If the cas is like a honda distributor you just set it to the middle and you should be good.
I need some more suggestions on what else to do? I have another ecu coming so I will try that when it gets here. It's only really bad when cold and when warm I can live with that cause it does sound pretty cool. It drives great and have no issues what so ever while driving, just the cold start idle is horrible and when warm it sounds like a v8 with a cam.
replaced all coils
tps is set to 0.45v
