I am currently "Balls deep" in my GTR build and i'm not quite sure which direction to take to make my car a reliable 500HP
This is currently what i have in my car and running, as well i'm going in to get a Link G4 ecu with map im curious if anyone has any idea what kind of power i might see out on the dyno after the ecu with map upgrade.
Greddy Intake plenium
Custom built Merge pipe
HKS Pod Style filters with stock MAF's
Yellow Jackets Coil Packs
Greddy Cam Gears
270* Cams
Supertech valve springs
Port and Polished Head
Tomei Head studs
Tomei Head Gasket Kit
CP Pistons
Mauler Rods
R33 crank
ACL race bearings
N1 Oil Pump
N1 water Pump
880cc Injectors
300LPH fuel pump
Twin GT2860-5 turbos
Straight Pipped with 4inch exhaust using stock headers
Act Extreme HD full disk Clutch
TurboSmart Manual Boost controller currently running 18psi with 20psi spike
for my ecu im running a chipped ecu
The rest of my car is stock except my suspension which is full nismo
opinions are very much appreciated thank you!
the rest of my car is stock except for suspension. Its Full Nismo
Greddy Cam Gears
270* Cams
Tomei Head studs
CP Pistons
Mauler Rods
R33 crank
ACL race bearings
N1 Oil Pump
N1 water Pump
880cc Injectors
300LPH fuel pump
