So my clutch won't disengage. I have a newish(3-4k) nismo twin plate - push type.
Heres what happened:
Car was working great. Parked the car in a parking lot - no issues. Started it, tried to put it into gear and could not get it in gear. Wtf. I hoped out and got someone else to push the pedal for me. There seemed to be plenty of travel in the slave but it would not go into gear. I then pumped the pedal about 10 times and presto! The clutch worked.
Drove the car out of the parking lot and got a couple hundred feet down the road then I lost my clutch again and could not get it back. Ended up towing the car home. I just got under it and had someone push the pedal. Still seems to be lots of travel. I even pulled the fork boot out and took a lot, nothing looks damaged and I can see the throwout bearing pushing on the clutch well.
NOTE: The clutch pedal went from being very firm and somewhat stiff to being very light and easy to push.
Two questions:
1) How far should the slave cylinder push the fork? Mine pushes the fork just over 3/4 of way (IE: the whole way being the fork touching the bell)
2) Any one else have any other ideas?
Two questions:
