So im going to start buying up a ton of shiny new parts for a huge build next year, just wanted to get some opinions
Car is a 1991 R32GTR, my goal is 500-600awhp
TOMEI BLOCK RESTRICTOR
NISMO BEARINGS
ARP CON ROD BOLTS
ACL ROD BEARINGS
ACL MAIN BEARINGS
TOMEI METAL GASKETS FOR INLET SIDE
HKS CAMBELT
TOMEI TIMING BELT
TOMEI SUMP BAFFLE
Mines TRIPLE FLOW CAM BAFFLES
TOMEI TYPE A VALVE SPRINGS
TOMEI FUEL RAIL
N1 WATER PUMP
ARP HEAD STUDS
TOMEI CAM GEARS
TOMEI PHOSPUR BRONZE VALVE GUIDES
TOMEI INTANK FUEL PUMP
TOMEI TYPE B PONCAMS 260/260 9.15mm
TOMEI DUMP PIPES
ATI 1000HP CRANK DAMPNER
TOMEI EXPREME TURBO OUTLETS'S
TOMEI EXPREME MANIFOLDS
TOMEI CONRODS
TOMEI 700CC INJECTORS
APEXI POWER FC D-JETRO
PAUTER RODS
TOMEI OIL PUMP
CP PISTONS 86.5mm
GARRETT GT2860 -5
NISMO PLENUM
NISMO BEARINGS
ARP CON ROD BOLTS
ACL ROD BEARINGS
ACL MAIN BEARINGS
HKS CAMBELT
TOMEI TIMING BELT
TOMEI SUMP BAFFLE
TOMEI FUEL RAIL
N1 WATER PUMP
ARP HEAD STUDS
TOMEI CAM GEARS
TOMEI DUMP PIPES
TOMEI CONRODS
PAUTER RODS
TOMEI OIL PUMP
CP PISTONS 86.5mm
GARRETT GT2860 -5
NISMO PLENUM
