1500$ RIPS or RHDJAPAN 900$ greddy or nismo 1900$? Rips best bang for the buck right? And the tb is included, good tb? My r32 makes 700bhp stock plenum... I think there will be a rips plenum coming this winter.... ahhh, would love couple millions coming my way....!
Their in house stuff has some really nice pricing, details on the Hi Octane Racing RB30 4WD Short Block 1500HP:
Hi Octane Racing RB30 GTR engine
The ultimate upgrade for the serious GTR
This engine is the result of countless hours of research and development in both time attack and drag racing. The Hi Octane RB30 features a highly modified RB30 Nissan block with relocated oil galleries, an extensively cross braced girdle retaining structural integrity of all main bearing caps, along with the highest quality forged rotating components resulting in a BULLETPROOF bottom end that will make most RB26 engines look fairly lame. The big difference with the RB30 over the RB26 is the length of the stroke. While both engines retain the 86mm bore (86.5mm in our case) the RB26 has a 73.7mm stroke while the RB30 has an 85mm stroke. The result of this is a much higher production of torque and useable horsepower at a much lower RPM range resulting in FASTER LAP TIMES and BETTER DURABILITY and longer engine life. This is the very engine we use in the Hi Octane/ Advan R34 GTR and you can see it in action in this video. This was the vehicles first ever outing and is using small dash 5 turbos.
The specs of the Hi Octane RB30 are listed here, is ready to bolt in to any GTR*and we freight WORLDWIDE please contact us for a quote
Parts Included
RB30 Block and Crank
Cp Flat Top Pistons with rings
CP High Horse Power Guegon Pins
Pauter X-Beam Conrods with ARP Bolts
ACl Race Series Conrod and Main Bearings
Crank collar
HOR 4WD Sump Adaptor and Girdle
ARP Custom Main Bolts
Supply and fit s/s welsh plugs
Work Performed
strip and clean block
supply adaptor plate and spacers
modify mains caps
machine block for adaptor
machine for oil pump
modify oil galleries
add oil pickup flange to block
convert head bolts to rb26
machine for rb26 oil drain back
supply all bolts washers and spacers
modify nose for oil pump
assembly
crack testing
pressure testing
sonic check bores
grind crank for oil pump
grind crank mains and pins
linish crank mains and pins
fit oil pump drive
modify crank for screw in plugs
cryogenic treat crank
balance crank assembly
torque plate and hone
Bore and hone to suit pistons
deck block parallel to mains
NOTE- 8-10 Weeks For Delivery
International Orders are GST exempt.
Model: HORRB304WD1500
Shipping Weight: 80kg
Manufactured by: Hi Octane Racing
Also, some of the duplicate items are ones i havent decided on which ones to get
none of the fun?
You could always look at things my way. I wanted to have fun buying parts rather than buy a build engine from a good source.
Going on my 2nd rebuild now (3rd engine, different shops) and I haven't seen 1500kms on any of them. Less than 1500km a pop failures were all assembly/machining faults. yes I should have bought a complete engine. I only wanted 500whp since my budget was $60k for a show car/week end track car. I went wrong when I bought high end parts and went to popular but mediocre shops.
Rips is nice but appears to be built for laggier/higher end power outputs than response. Bigger doesn't mean better in every way. A laggy 500whp is slower than a well built low/mid range 450whp.
Since you can afford a serious build, why not go Rips RB30? One of the best engines out there which costs only slighly more than a tomei 2.8L (about $12k vs $11k, bottom end only). I had planned on doing that for round 3 but I have too many parts I can't see (low interest in quality used parts), so I'm stuck with what I have.
Taking in mind what you said, i've decided to order a nice Rips RB30
