Hey guys hoping i could get some help just finished putting a new clutch in my gtr and replacing a coolant hose that goes to the block underneath the intake plenum got everything back together and tried to start it for the first time in 4 months it almost fired up then i heard loud bang kinda noise and now it will just sit there and crank but wont start i have fuel spark compression and air any ideas on what it could be!? car was running perfect when i parked it 4 months ago
R32 GTR cranks but wont fire has spark and fuel HELP!
Could be. I'm thinking didn't check straightness of intake plenum flange and blew intake gasket??? Or ACCV paper gasket has blown (engine won't idle)???Originally posted by steveo1502 View PostSounds like it backfired and blew off a boost tube, happened to me a few times, check for boost leak
Engine usually doesn't start if CAS is unplugged or set incorrectly. If engine has sat for a long time (months), usually has rust in bores, etc (use fogging oil down sparkplug holes to prevent this from happening) and needs a boost with battery booster to get engine to crank over and start. Had to do this to my car after sitting for 6 months, even with a charged battery.RESPONSE MONSTER
Start with what components you worked around that could have caused this issue. Grounding straps, other wiring, hoses around the coolant hose you replaced. If it ran fine before its good to verify your work before diagnosing a no start issue.“Hey, come on, its a car right? No. It’s a symbol of your history, its a thread of continuity from which you came to where you are. It’s important that you don’t want to forget who you are.” -Dr.Phil in "Love the Beast"
Please let me know how you tackle the problem....my car (R33GTR) cannot start after I cracked the intercooler....
I have been messing with the fuel pressure and it won't start now...I can hear it fire up a little while cranking at 200~rpm. Swapping Power FC and stock ECU make little difference... I know I have fuel and spark. I think my case is a vaccum leak (from the intercooler)
Before it won't start anymore it began to lose power and HORRIBLE mileage (half tank for 30 kms) and when I let go the throttle I could see a huge black smoke from my rear view mirror. Probably yeah check for vaccum/boost leak...
This is crazy, my buddy just had this happen to his STI. He swapped out the clutch, and when he put everything back together the car wouldn't start. He traced all his ground wires, and he found one going from his ECU to ignition coil melted. So i suggest tracing all the ground wires and making sure they're all secured. Another thing you can check is the clutch relay.
I had a similar issue last spring after taking my car out of storage, it would just crank but wouldn't fire up. After 2 months of troubleshooting, it finally came down to swapping the ignitor box on top of the motor (at the very rear) and changing out my plugs.
That can happen to RB engines as well (fault with loom to igniton module from ECU). Igniton module itself sometimes can be the cause, but engine won't start when it's hot and then once cool engine starts and repeats. Most of starting problems I have had were traced back to faulty CAS, intake airleaks.
In some rare cases leaking headgasket can be the cause.RESPONSE MONSTER
Are MAFs plugged in and everything? Pull the CAS and spin it to check injector operation, check fuel pressure, There are some very fine grounds on the coil harness that are easy to break so check those. As described above I can see this being a ground issue as something was broken or dislodged as engine shifted down to slip off transmission.
