I recently tore apart my motor cause of some oil leaks, it was built with supertech forged pistons and all the machine work was done at a reputable machine shop
there seems to be scoring marks near the lower half of the cylinder wall, some are not very noticeable but 2 cylinders the marks can be felt by running my fingernails across it
Not sure if I should be worried, but I've read that sometimes the piston skirts can make marks on the cylinder walls
before teardown compression test was done and results were around 160 across so doesn't seem too bad, never burned oil; considering that results are on forged pistons with wider clearances, its not bad at all
UPDATEL: Found the problem....
Thrust bearing thats been shaved off by about .4mm all copper material on flywheel side is gone, just been one problem after another...
