Alec's did the machine work and I did the assembly, they did a good job, only complaint is that there may have been some miscommunication but I think when they decked the block they were under the assumption I wasn't using a MLS head gasket, the surface still had ridges from the decking passes, didn't think too much of it til i found coolant in my oil pan
I don't think its because of ring gap, they were filed down to the specifications sheet that came with the pistons and i checked them myself with feeler gauges before installing, checked the skirts and they seem fine, the dry film lube is still on the pistons a few has a streak or 2 on them, I think bearings are okay, I will check soon
during assembly all main and rod bearing(ACL) clearances are checked with plastigauges and they were all within spec of FSM while being a little on the higher side which is not bad
I think it may be debris that got into the motor but i just dont know at what stage did that happen, I assembled the motor inside my house and i kept everything as clean as possible
