Hey,
So this is turning into an exciting spring. When the car was being started, one of the idlers failed and so the timing belt jumped. The car didn't start. The idler, pulley and belt were all replaced, but the shop says there's no compression in the engine and it's not firing, suggesting that all the valves are damaged.
This all makes sense so far, correct? I know they haven't had the head apart to see how badly, and I've not looked at it. But if you guys had to guess, what's the damage and best course of action from here: get new valves? get an entire new head piece from a used engine maybe?
Thoughts?
Thanks!
Thoughts?
Thanks!
it finish cost me about 1500$ with everything but i remove the head directly in the car can be alot less if you have the time to shim the cam after
