Been researching through google, and tried a little search on GTRC. Came to the conclusion there's a lot of people that don't rev past at the most 8500rpm, and then there are a few rock stars out there revving to 10k! This is why I've come to you.
So, now that I've been to the track a few times (drag strip) I've been analizing my footage and logs and from what I can tell, without changing to different tires (currently on street dz101's) or upping the power of my ~500whp gtr (pump gas) that maybe drawing out the gears a bit could help me to get into low 11's or even high 10's.
Right now I can consistently attain 11.7 second passes @~120mph without mashing the gearbox too hard. I'm shifting at 8200 rpm currently and having to shift into 4th before crossing the line losing precious time. I'm thinking if I can hold it until 9000 in 1st,2nd,3rd I might just pickup a few tenth's. (I'm still pretty new to the track)
So, currently I have a fully built bottom end (carillo pro rods/bolts, 87mm wiseco pistons/pins, acl race bearings, lightened & balanced r34 crank and trust extended sump), 1000hp ati damper, tomei re-inforced timing belt, jun oil pump n1 water pump, and as far as the head goes, fully ported, small oil orifice, new oem guides, seals, valves adjusted to spec, stock springs, stock valves, 264/264 9.25 lift cams. And a sweet a$$ Borg Warner turbo.
Basically in your opinion if I install a set of type b springs or some other stiffer springs do you think this will suffice @ 9k?
Thanks guys!
Eagerly awaiting your responses.
FWIW this is home built baby!
Brent.
Thanks guys!
Brent.
