Engine building advice
    I suppose, but you and about 5 other guys on here are in the minority with the whole machine shop black hole phenomenon. The skyline bible tells you all you need to know. With that information and a shop that has built a decent amount of high performance motors you should be fine.
    They guys at the machine shop will do whatever you tell them too. Give them the piston manufacturers sheet on skirt clearances, the specs on brg clearances from the bible and tell them that this is a motor that will turn 9000 rpm and put out 700 hp and they will get the picture. If they don't seem to grasp the seriousness of the build, move on.
    Your best bet is to talk to the motorcycle shops in town and see who does their machining, those guys will understand a small engine making stupid power practices.
      Yeah, my engine had come from Z-tune in BC. Lasted 2 weeks.
      No build thread.
      1991 nissan
      El terror
        wow scary sh**s whats the big idea behind the myths is it really that hard for an shop to built an engines all they is to it is clearance and balance, is there really that much people out there blowing fresh built engines or people just talking i need to see some pics...
          sorry to ask dude u got pics to back this up..
            I guess so inspector Columbo, ill upload some tonight. Even got a video of the crank thrust being beyond clearance.
            No build thread.
            1991 nissan
            El terror
              My new N1 tomei stroked engine is for sale (still in box, nothing touched yet) so I can buy an rb33 or rb34 from rips!
              No build thread.
              1991 nissan
              El terror
                This ^ happened not only to you my friend. There's a couple of us on here that either bought engines directly from ztune or from a certain tech that worked for ztune. We've all encountered the same fate.
                A good deal is only a good deal if it lasts.
                  I really dont know why all the past issues were happening. Really, it's a piston engine, not a nuclear reactor. There are 14 brg clearances to check and 6 piston skirt clearances with 12 ring gaps. If one is wrong you fix it, not bolt it back together and cross your fingers. Must have been a bunch of cases of "I don't give a rats-ass".
                  I never get tired of linking this story. Not only does it hammer home how tough the GM LS motors are BUT how making sure a STONE STOCK engine is set up properly can allow it to take a beating...again and again and again......
                  FORCED INDUCTION - LS Power!! Twin 76mm Turbo 4.8L 1200HP & still going!! - Info is from a local forum: http://img715.imageshack.us/img715/9053/ttsbc1.jpg http://img17.imageshack.us/img17/1299/ttsbc2.jpg http://img535.imageshack.us/img535/1562/ttsbc3.jpg http://imageshack.us/f/200/ttsbc4.jpg/ so to all you lsx boys.....
                  In the end, it was discovered that this was a 4.8L truck motor, not the 5.3 they thought it was.
