I ran the AMS aftermarket front upper control arms without replacing the Tension rods and one of the wheels camber really went out one day (-2.2)
Took my car to get aligned and the rear camber was -2 degrees.
He wanted to adjust it into spec but one of the camber arms adjusters was stuck. ended up with -1.5 and -2 and the car is not riding so good.
I guess running aftermarket upper control arms have softened my tension rods and it pulls ever so slightly under braking. The front suspension also has started clicking in dips. I'm guessing the front arms are worn out or not in spec.
tldr: my suspension front and rear needs a rebuild.
Front Suspension:
used R32 GT-R front upper control arms and rebuild them with new bushings (save some money?)
Nismo circuit Link set (tension rods, new Bracket, Lower arms)
Might be a good time to also get new tie rods ends, how can you tell if they're worn?
Rear Suspension:
New OEM rear camber arms. They're the same as the 300zx right? Also, I am having difficulty how the stock camber arms are adjustable?
Front Suspension:
Rear Suspension:
