Haltech Platinum Pro ECU
there was no codes on my ETS before but now I get a code 21 (throttle sense). I get a 4wd light on the first start of the day but every other start in the day no code. When light comes on yes I get 2wd only. I have followed the manual to trouble shoot but everything checks out -
replaced tps
replaced ets
and wiring must be ok because the fault only comes on with the first start of the day. Turn engine off and restart many times after and no fault
Sooo to my question and what I am working on. In the Haltech manager software... in setup (F4)
TPS input I set to .5V no throttle (in the tuning software) and press throttle to floor and hit set and comes to 4.8V ish
The tps input filter recommends 5 I believe and have tried 0 to 8 and 21 code still pops up.
TPS output setting I just found which is the setting for signal out to the ETS in the trunk. I just set the filter to 10... I started once (cold start) and no code but this is nothing new its intermittent. Second start got code 21.
Soooooooooo I guess the main question would be has anyone know of someone that had 4WD issues after new ECU and what would be a safe setting for the TPS input filter and Output filter??
replaced tps
replaced ets
