hey guys.
i have a problem of overheating that only occurs when i boost the car.
Normal driving days, without too much boost, i can drive around, traffic, highway city and the gauge always stays normal running temp. When i turn off the car i hear bubbling coolant in overflow once in a while.
its not the same when i use the car for its power. when i start to boost the car, the temp usually starts to grow
and stays at the 3/4 mark on gauge and that, after 1 second gear pull, give it two three mins the coolant is boiling.
the car has been stored for 6 months without any issues last year, and i have started to roll the car its been around 1500 kms, without too much abuse.
i have replaced the termostat, replace the rad cap with gates 1.3 bar caps, tried 2 of em still overheats.
starting to think it might be the head gasket starting to fade away.
what i did up to date:
any tips would be welcome.
- i havent used a pressure test,
- the coolant doesnt bubble in rad cap when the cap is off and engine running
- no oil in coolant.
- no coolant in oil.
- no white smoke coming out of exaust on idle, boosting, and normal load.
thanks i need some help.
