Yeah key on both fans are on, i ran on a relayed circuit from 12v battery and earth, getting signal from original a/c wire.
overheating problem r32 gtr
N1 waterpump for racetrack use (reduces cavitaton / creation of airbubbles at higher rpm) and stock waterpump for low rpm street use (stop and start traffic, etc). Have look at Nismo RB26 S-tune (Street), R-tune (Race) RB26 engine specs to see what I mean. If using for track days or sport driving on the street, you might get away with using a N1 waterpump. It's application specific.Originally posted by mistercrow View Postalright i will order a new water pump, anyone got n1 part number or stock does the job?
The radiator cap you have should be ok with an aftermarket radiator, just if the waterplugs blow, you'll know why (especially on rear of head which seems to be common area it fails at on a RB26). I think they weld the waterplugs in place or similar to stop them from blowing on RB26 race engines (do some research on this).Originally posted by mistercrow View Post2:what is stock rad cap pressure?
That is lean and could explain the higher than normal coolant temps. Around 11.4-11.5:1 is safe under full throttle, full boost with a "stock" engine.Originally posted by mistercrow View PostI run power fc with djetro, the car doesnt run lean at all, got tuned a month ago. Wideband shows 11.9-12.5 full throttle and idling around 13.8-14.1
With 260 duration cams it would run richer than that (more air entering engine, so need more fuel).
Tomei mentions the recommended A/F ratio for the cam specs at idle, idle rpm to suit (also show the rough A/F ratio's for similar cam specs for turbo engines) -
They say around 13.0:1 A/F ratio at idle for 260 duration cams, 1100rpm for idle. Around 13.8-14.1 is quite lean for those cam specs.
I would talk to the person who tuned ECU/engine, as the ECU/engine definitely needs a retune.Last edited by Skym; 06-16-2014, 06:33 AM.RESPONSE MONSTER
You're welcome. It might be just the tune causing the high coolant temps, everything else might be ok. Fix the tune or find the cause of the lean A/F ratio (if the tune is ok).
Sometimes it can be leaking intake gasket or exhaust gasket, but would see at least 17's (stock??? engine) for A/F ratio on wideband if it was that (picks up on the leak / extra oxygen).Last edited by Skym; 06-16-2014, 08:50 PM.RESPONSE MONSTER
alright so last night i had a bit of time to play on the car. i baught myself a head gasket tester like i saw im previous link comments,
the blue test witch turns yellow if there is co2 in coolant.
i used the blue test at cold start, and pumped through it for about 5 mins, never did the product go green, so i elimintate that possibility,
baught myself a pressure tester witch i put at 1.4 bar and kept it there for 20 minutes, the arrow dropped to 1.3 bar in the first minute then stayed there, so i dont believe i have a leak in the system.
i will put a 0.9 rad cap this weekend and clutch fan, go race the car a bit and check if it overheats. if it does ill go see tuner.
Ok so heres what i found out at the races.
Put new rad cap o.9 bar with the two mishimoto fans, i start a drag race lets say at 90° celcius, go for a quarter mile, finish race around 92°.. Get off the track start to roll slowly it goes up to 100° celicius 2-3 mins after the race is over. If i park the car and turn the key off, the temp goes up to 105 and stays there. Fans are on though.
Got no idea where to look now...
Mostly likely the lean A/F ratio at idle or due to N1 waterpump (more for high rpm use, not stop and start traffic, idling). Coolant temp rising after engine is turned off is normal. The coolant temp should drop and stay at a constant temp when engine is turned on (if cooling system is working correctly and tune is not too lean).Last edited by Skym; 06-20-2014, 02:21 AM.RESPONSE MONSTER
heres what happened throughout my night, sorry ima repost the drag racing part.
took the car today, after putting in new rad cap and new coolant mix, started to look at cluster water temp and power fc water temp. I noticed the power fc water temp is pretty more constant then the cluster. I also used to run water , flushed everything to put a 30 coolant / 70 water mix. still boils after shutdown like it used to (takes around 2 minutes to start to boil). water temp on cluster is actually pretty inaccurate, or not stable at all, once in a while at 90 degrees it was in center of gauge, other times it was 3/4 at same temp, so I said **** it, reading only power fc values.
Power fc, in traffic, redlighting, normal driving would read an 83-85 degree coolant temp, on highway it would read 75. (on cluster gauge would always be center but would go a bit over halfway mark after a very long period in traffic) At the drag races I started the race at 90 most of the time (center of gauge), to finish around 91 most of the time, and then everything was fine until revs got much lower for a longer period of time. the coolant would rise to around 105 on power fc, after 3 to 5 mins idling, or driving around slow.
my question now, what are normal running temps for city driving, highway and racing days? maybe just the cluster going crazy and my 100% water coolant was kinda crappy, but I never had any issues with boiling water in a coolant system before? is there something not going on right?
I only did the head gasket blue test/ pressure test on a cold start/ cold engine, should I do it on hot engine also? I have a tendency to think that the head gasket might leak a lot more on cold start then hot.
the coolant still boiled after the final shutdown today, with a 95 degree water temp.
I might be paranoid, but i just really don't want to end up with a cooked head and a blown headgasket...
Roughly 30% coolant to 70% water is probably part of the cause, as I think the coolant helps to prevent overheating.
The 80 degrees C is factory at idle, not uncommon to see up to 84 degrees on some modified engines at idle. My cars engine sits at 82 degrees C constant at idle.RESPONSE MONSTER
Yup...and make sure the fans are sealed propperly to the rad. Do you know the wattage of the fans you are using? They should be at least 150 watts while operating pulling close to 18amps a piece. Electric fans will pull twice the amount of air as a stock fan when you are just putting around below 2500rpm. The N1 pump still flows enough at just above idle, I pulled a rad cap off of a car that runs one and observed the coolant flow at idle with the thermo fully open and its plenty, that really shouldnt be an issue.Originally posted by Black BNR32 View PostIncrease your timing at idle.
Get a smaller water pump pulley, which will spin your pump faster at low speeds.
The ignition timing off boost is a huge factor in a motor with low compression and running close to 100 octane fuel.
Jon.Last edited by Dragon Humper; 06-20-2014, 05:58 PM.Why don't you come over to MySpace and Twitter my Yahoo untill I Google all over your Facebook.
