so this may be a mildly long read but i appreciate your time and it won't go wasted. so I'm planning on building my car over the next year, I've been going for the past almost year and this is whats done. i bought it bone stock with a hks silent hipower axel back. i then removed the cats, etc. bought a big fmic, greedy hard piping, turbo smart race port bov, apexi intakes, turbo smart manual boost controller, B&M oil cooler, Mishimoto rad, aem ems series 2 with map sensor, os giken ts2bd. the car is at 130kms and dynoed 348 whp and 274 torque, i street drive mostly and maybe 2-4 times a year will take it to the track (time attack and drag) so I'm looking for almost a best of both worlds. i will be building the bottom end in the far future so i just want to build everything else up and sufficient for my end goal of 700ish whp and tune it down till the bottom end comes into play for now, my goal is to reach about 500 whp which i know is safe if not ripped on all the time. so heres my question now, i know i will be doing 1000cc deatschwerks injectors, bosch 044 fuel pump, undecided on the brand of oil pump, different intake manifold but i should be good on stock for 500 i believe but id like to go single throttle body in the future, tomei cams, 1.2mm head gasket, head studs, what else would you guys advise in the head? over size valve, springs? probably going with a top mount manifold and external waste gate , and turbo is another one I'm stuck on , I'm pretty good feeling about the garrett gt38 but i don't know about a/r's i still have to do some reading in that department. i know this topic has been covered plenty of times but not quite the way I'm building. please don't rip on me, just looking for advice and trying to learn more as everyone did at one point.
Cheers!
Cheers!
