Worth using an adjustable FPR on stock rail such as the Nismo or Tomei? 044 pump out back and mildly built engine.
Adjustable Fuel Pressure Regulators?
If want more fuel out of stock or aftermarket injectors. It's a band aid way of getting more out of injectors instead of upgrading injectors. The other reason is if running a higher boost level and the boost pressure in intake manifold prevents fuel from exiting injectors, thus making engine run lean, you then up fuel pressure to match. As far as I know, most FPR's are 1:1 (1psi of boost = 1psi of fuel pressure).Last edited by Skym; 08-17-2014, 09:04 AM.RESPONSE MONSTER
