Adjustable Fuel Pressure Regulators?
  • Adjustable Fuel Pressure Regulators?
    Worth using an adjustable FPR on stock rail such as the Nismo or Tomei? 044 pump out back and mildly built engine.
    I don't think so. I'm making 427whp on a stock fuel system with 550cc injectors.
      If want more fuel out of stock or aftermarket injectors. It's a band aid way of getting more out of injectors instead of upgrading injectors. The other reason is if running a higher boost level and the boost pressure in intake manifold prevents fuel from exiting injectors, thus making engine run lean, you then up fuel pressure to match. As far as I know, most FPR's are 1:1 (1psi of boost = 1psi of fuel pressure).
        i run a AEM FPR, also have the AEM fuel pressure gauge inside the cabin to keep track of everything. Great investment imo
