Wheel fitment thread.
This is a sticky topic.
Final fitment with front bumper and skirts. Rims finally fit without rubbing anywhere and look nice in my opinion.
18x9.5 +12 TE's. Rolled and pulled fenders. Removed front fender liners. Rolled back inner fender where skirt mounts and moulded skirt around it. Some other modding here and there but here it is.
That's all you get.
Now if I ever get it finished and painted.
will 17x10 with 0 offset fit with gtr fenders in the front and 17x11 0 offset in the rear with 50mill overs or less? buying a skyline this summer and want it fitted properly lol
hmm I am loving this fitment...
HKS Hypermax Coilovers
Advan Model 5 19x10 +19 (all 4)
245/35 Front Falken Azenis ST115 (brand new)
275/30 Rear Toyo Proxes T1S (brand new)
Rear Fenders have been rolled and slightly pulled (about 5mm) this set up does not rub under hard or soft driving!
Front Fenders have been rolled aswell.
You should beable to make it work with your tires size now and a small roll, no pull.
Id keep your tires size and roll the fenders to fit though, dont sacrafice a small tire so you dont have to roll.
Ok. Just another question.
Like I said earlier, I have 18" Volk GT7's. With 18x8(not sure of offset) with 225/40r18 in the front and 18x9 +29 with 255/35r18 in the rear.
It currently sits and looks like this:
This is the gap in the rear:
I would really like to go lower just to give it a better stance. I don't mind rolling the fenders. My buddy and I plan on doing that this spring. I would also be willing to go with a smaller tire.
So the question is, can I make it work without having to pull my fenders? What size tire should I go with?
Thanks for any help.Last edited by Jezu21; 02-13-2011, 08:57 PM.
i got some 18x9 +28 (front) and 18x9.5 +25 (rear) coming my way. Im thinking they are going to fit pretty darn good on my stock skyline
I have a gtr front end waiting to be installed and I will go low. I know +20 in the back will make the rim poke a little and want the same result to the front ( keeping in mind i will have gtr fender installed) That why I have problem figuring how the same width wheel can have a good offset without looking strange. BTW the rear is alrealdy rolled. I think my best bet is having 9'' +20 all around with 30mm spacer in the front.
Well. A lower usually does result in a bigger lip or more dish. But thats just how a lot of wheels are made. If your going to run 9 inch wheels all around. your going to want a little bit of a lower offset for the rears.
I run 17x9 in the rear with +20 offset.(with spacers) and 17x8 in the front with about +25 with spacers. Fronts are perfect and so are the rears. If you have the "proper" size tire you will need a roll in the rear. If you run a bit of stretch you will be ok.
All depends on how low you are. and what kind of fitment you are looking for.
if you use willtheyfit.com. It gives you how much the wheel will stick out compared to your old wheels so you can estimate if 30mm overfenders will be needed. Great site
I know larger rim would be different, but considering that I want 9'' wide rim all around. Larger rim on front would look strange but lower offset on the same wide wheel could result in having a bigger lip in the front ( I think). Wonder if GTR and GTS-T have the same front ( same hub to hub distance on the front) I could use a proper fitment for gtr and go from there. For everything else there is always spacer.Originally posted by RHDskyline View Postyour using very good logic there. I like it haha. But rim width plays a BIG part. cause -10 on a 7 inch wide rim will fit WAYYYYY different then -10 on a 11 inch wide rim.
use willtheyfit.com to get your proper fitment
Originally posted by Jezu21 View PostI'm running 18" volk GT7's
I have 18x9 +29 with 255's in the rear. And it sometimes rubs if I'm going normal speed and there's a big enough dip in the road(it happens more often if I have a passenger).
Would a roll fix this? Or a smaller tire maybe?
I'm getting new tires in the spring, and I'd like to have this problem fixed so I don't ruin them.
smaller tires and do a fender roll. its hitting the lip and its hitting your fender. you need to flare you fender out a bit if you doin't want to buy new tires. if you buy smaller tires you can probably reduce how much you have to roll the fendersLast edited by RHDskyline; 01-29-2011, 01:10 AM.
got a question about gtr fender on gts-t. I know gts-t with +20 will have the rim poke out a little. If i put gtr fender (+30mm) will i need -10 rim for the front to get the same result? Iam missing some info .
I'm getting new tires in the spring, and I'd like to have this problem fixed so I don't ruin them.Last edited by Jezu21; 01-28-2011, 11:29 AM.
Haha I figured they would be DR's with those specs. You could convert it to 4-lug, its not unheard of haha. Look at the S15 from TAS this year though I dont necessarily think thats a good idea, especially since you would have to run smaller brakes.
