ok so my build is going to consist of:
RB20 Stock engine with a 3 inch turbo back exhuast
Walbro 255 lph pump
HKS SSQ
Stock RB25 Turbo
Apexi SAFC 2
Wideband Unit
SS oiling lines for the turbo
i'm hoping to run a little more boost (lets say 11 psi, my stock RB20 is running 11 right now but tapers off to 10)
as for power goals, i'm not looking for something crazy but just 250-280 WHP
if there is a way to safe to make 280 whp without buying a new turbo then please let me know.
i know the connecting rod bolts are the weak spots on the RB20 when your running more boost so i was thinking about ARP con rod bolts, head studs and a Gizzmo head gasket. only thing is i'm running my RB20 in a 240sx and would have to totally pull the motor to do the conn rod bolts.
i just want a bit more power as my buddy with a slightly modified 1.8T jetta stayed right on my ass last night with me running a bit rich and going full out! i need to be faster then a jetta lol
if there is an easier way to make more power without breaking anything, taking the motor apart, or changing turbos let me know. this set up was gonna cost me about 4 hundred bucks so if i can get the same kinda power in that price range it would help alot.
what are your thoughts guys?
Walbro 255 lph pump
HKS SSQ
Stock RB25 Turbo
Apexi SAFC 2
Wideband Unit
