I just recently did a rb25 swap into my r32, I cannot get the car to start, turns out there's no compression in any of the cylinders, there's spark, fuel and the engine spins, I purchased the motor from a reliable seller who says they tested the compression and replaced the timing belt and all was good.
I didn't mess around with the timing or remove the cams so I don't believe there is any possible way I could have bent the valves, let alone all of them. the only thing I did mess around with while trying to get it started is the cas, is it possible that's the cause of no compression? and if not does anyone have an idea what else could be causing the problem? I have yet to pull the head off to check the valves.... Also its a series 2 rb25 and it has hydraulic valves
Any help would be greatly appreciated
Thanks
Thanks
