Ive been doing some research and it looks like the 3076 will be a good fit if my numbers are right. I used this site to figure out:
349.615200515625 cu ft/min = the volume of air entering my engine
15psi = or roughly 1 bar as my benchmark boost
125 F = manifold intake temp
47.972148 = lbs of air per minute (ideal)
43.1749332 = actual air flow (lbs air/minute) using 90% efficiency
70 F = ambient temp
pressure/compression ratio = 2.3
41.82405027 = corrected flow (lb/min)
So now I can take 2.3 and 41.8 and plot them on to a compressor map, its not an exact science but it should be close. Looks like its its around 75% efficient, with lots of room on the right side for upgrades and no where near the surge on the left. http://himni-racing.com/index.php?ma...image&pID=1852 makes me wonder if it would be closer to perfect with a .83 A/R.
I found this site that seems a little different for figuring it out, so Ill try it and see if it comes up different.
70 F = ambient temp
