Full Tomei rb20 head! In put please!
  • Full Tomei rb20 head! In put please!
    Hey guys!
    I just picked up my spare engine wich i will start working on shortly after the skyline is done.
    Right now the rb20 is having tomei poncam, 1000cc ID injectors, aeromotive 340lph fuel pump, gt-r machined intake, full custom exhaust manifold with gt turbo, full custom exhaust, haltech pro-plug in computer.
    For my next Engine set-up, i am thinking, going with the tomei procam stage 3 with a 9.25lift, solid lifter conversion, tomei spring valve,valve, valve guide, port and polish head. I will also balanced and cryo treat crank shaft, full arp bolt/stud.
    My goal is to have a 450whp reliable 9000+rpm rb20. Right now i am at the reading to part to make it possible, but with my actual rb20 and turbo set up, 400whp is possible.
    I want to know what you guys think, what i should run if you have any other suggestion. The car is mainly use for roadracing.
    Please don't tell me go rb25 or **** like that.
    Alexandre Canuel
    PERRY AUTO LAVAL
    PERFORMANCE & RACE- OEM
    REPLACEMENT
    450 662 8886
    If you got the money, DO it. No one that I know of has those numbers on here.
    Would like to see it built.
    ok so i've spun a big end bearing on my RB20DET so it's time for rebuild i'm wanting to get a bulletproof 280rwkw that i can go bash on the limiter all day at the track and i want some opinions on what sort of setup would be best so far i'm thinking bore and hone the block, port the head, run hks...
    92 Gtst/Silver bullet
      That sky will never come alive. Keep dreaming into your Vtec civic xD
      I'd like to see those numbers on a local GTS
        Thanx max appreciate the kind word! This set up i might start only next winter, i checked my cost and would be around 2300$ for the head but this was without the valve and no work put in the head. I know i should'nt build another 20 but i love those engine. I am on the finishing touch for the skyline and will make it run this summer after 3 years of putting it together.
        I will also upgrade from my custom exaust to a full race twin scroll manifold in the upcoming year and a half with a precision turbo, it might be a 6262 with the new wheel design and ball bearing to make it breath upon those rev.
        Alexandre Canuel
        PERRY AUTO LAVAL
        REPLACEMENT
        450 662 8886
          All powers to ya, I'm taking the same path w/ my 2L instead of doing the cookie-cutter 2.5L
          What piston/rod combo are you thinking and where do you find them? (I can only find supertech pistons and no rods so far)
          I'm making 420BHP on a 20 w/ ARP headstuds, HKS cams and GT3071R @ 16PSI (no meth), but my next block is going to be built for 24+PSI w/ meth.
          PS: I'm running 9.0 lift on hydraulic lifters w/ no problem, so your solid conversion should have no problem if you upgrade springs and retainers too.
            413rwhp R32 RB20DET racecar with stock cams, etc (look at comments on first, second page for mods) -
            On racetrack -
            Add probably another 24rwhp or so with Poncams.
            Higher hp engines = less hp down low. If for road racing, don't you need hp down low???
            If so, compound turbocharging gives best of both worlds -
            Driving with compound turbo setup -
              Yes i will change the spring and retainer. For the Rod, from what i could see, the stock one, could be more then enough. I was thinking of getting them shotpeened to strengthen them. As for piston i will calculate the clearance up first, see if i have to go custom piston or not.
              I will also run meth, but to keep my cylinder temperature low, since the car will be beaten on the track at least once a week, i want to get the most reliability out of it.
              Maybe one day i will make a build thread, i never did one... But for the one that may asked, car has every suspension part from whiteline except rear swaybar, wich i kept stock. Hsd suspension, Haltech pro-plugin with IQ3 racepak dashlogger, full stripped, Brake are hp+ and brembo all around, but will be running dtc-30 front brake pad for time attack on street tire. Full supporting engine mod+oil cooler. Custom intake and exhaust manifol/downpipe. gt2876r( i know not the best, but had a stupid deal for one of those.) Caged will be done once the car start.
              Alexandre Canuel
              PERRY AUTO LAVAL
              REPLACEMENT
              450 662 8886
                Skym, You need power down, but with this set-up, i don't think i would find myself really under 4500-5000rpm. which is where i want to be when exiting a corner.
                I will check in those compund turbocharger!
                BTW the guy in the video is running the Cobra evolution seat, which i am going to run also, i love this seat, so comfortable!
                Alexandre Canuel
                PERRY AUTO LAVAL
                REPLACEMENT
                450 662 8886
                  idk like too see a build thread on this, i am going full tomei valve train on my spare rb25 head, it wont be as wild as yours since i dont have enough money to machine pistons and get into the bottom end yet
                    The build has been under going for 3 year, i am not a fan of build thread either. I will take picture and would be able to send some to you.
                    Right now my turbo setup is up for sale i am going precision 5858 and full race manifold.
                    Alexandre Canuel
                    PERRY AUTO LAVAL
                    REPLACEMENT
                    450 662 8886
