so ive got a gts-t with not huge plans on the brakes.. its only been daily'd for the past couple years and im about to start doing much more drifting on the track and i just want good brakes... drifting isnt really the reason i just want to stop quick when someone cuts me off...
my car came with slotted rotors and and hawk hp pads all around and ive never changed anything. i recently removed ABS and i heard you can use better then DOT3 brake fluid if you dont have ABS. anyways should i get dot 4 or 5? i dont know much so you dont need to get all crazy. i remade all the brake lines in the car. with the new copper nickle stuff. and added a proportioning valve to help balance front to rear braking power to calipers.
the plan is to get my rotors turned back to nice smooth finish for the new pads ill buy and the new fluid and lines to help out as well...
some guy gave me some AMS carbon ceramic rear pads when he shipped someone else and i was going to use them and buy the matching fronts. kuz i heard carbon ceramic is a good mix for daily/track. and i hear that style of pads do squeal but oh well...
what do you recommend! if you know more about fluid or pads say whatever you want i need to learn. but this car is being build for more track car and i dont want somehting that only works when its hot like a full crazy track car, and i bet thats really expensive.
should i go to project mu?
thanks
Marc
thanks
Marc
