well im building a nice powerful daily rb20 with a nice power goal in site. last motor i built was a b16a turbo motor for my civic sir and i used kings bearings in it. any one used them on rbs? or have any other internal parts brands they like ? thanks!
internals which ones?
Can buy a forged RB20 bottomend kit here -
With ACL bearings, headgasket, etc -
I would change headgasket in that kit.
Factory upgraded bearings are coated to withstand more heat and can get ACL bearings in above kit coated here -
AS9100D certified performance coatings for aerospace, defense, and motorsports. PVD, DLC, Teflon, ceramic, and dry film lubricants engineered in Denver, NC.
You can get away with Forged ACL or CP pistons, stock forged I beam conrods with over 400whp.
That's what this RB20DET powered racecar engine has (ACL pistons, stock forged I beam conrods, new stock conrod bolts, stock crank, upgraded valve springs and probably a metal headgasket, Accusump, etc). Specs are listed in comments and on his website -
On dyno -
Also ACL make a metal headgasket. Tomei, ACL are the metal headgasket's to use.
If going for higher boost levels, look at replacing stock intake gaskets with custom made copper or similar gaskets. You could fit O rings if want a stronger seal.
If want 1mm oversized valves, valvesprings, valveguides (to suit oversized valves), etc, can buy them from Supertech -
Supertech Performance offers high quality racing components, valves, pistons, spring and valve train engine components for the automotive industry. We are the leading manufacturer for high performance valves, pistons, springs and valve train engine components.
Tomei sell cams, valvesprings, valve guides (for stock valves), metal headgasket and Tomei RB20DET crate engines in 2.2 litre or 2.4litre.
If stroking the engine with Tomei pistons, would advise to fit some sleeves, as used on HKS stroker kit for RB20DET (don't think they sell it anymore). It's best to leave it stock bore or 1x over size with forged pistons for maximum strength with block.Last edited by Skym; 08-28-2012, 05:57 PM.RESPONSE MONSTER
You're welcome.
Also you'll need a aftermarket crank collar (can buy from Spool, as mentioned above, JUN in Japan, etc) to be fitted to stock crank, as stock oilpump drive is too short (I assume a design fault). The stock oilpump drive is machined off and the new collar is heated, pressed on, cooled and grub screws are fitted to collar to stop it from moving. This is done when engine is apart.
If go with N1 oilpump, buy the stronger, better designed Reimax gears and keep stock revlimiters. If going outside revlimiters, look at the more expensive tuner oilpumps. Also you probably would need oilrestrictors, as RB engines move alot of oil to head under constant high rpm.
Have a browse through the Tomei catalogue, as most of the known problems with RB engines are mentioned there -
