Does anybody have any experience with CXRacing exhaust manifolds for the RB20/25?
CXRacing - Manifolds
Yah I had one that came with a setup that I bought off someone. It was a bottom mount and it cracked within a year. I would recommend staying away from manifolds that are made from 304 stainless steel as you are just going to have to replace it. They are bound to fail. Some faster than others.My R32 GTS-T 'Swagger Wagon' Build
: http://forums.gtrcanada.com/gts-project-cars/63889-jareds-swagger-wagon-90-r32-gts-t-rb20-build.html
It is a waste of money and time from my experience. Even if you spend the time and or money to reinforce the welds or modify it flows like crap compared to a quality 6boost/old greddy/fullrace/rawbrokerage manifold setup.
Those are just the ones mentioned Id trust/ and or had a chance to ride in with those manifolds.
Your wallet,gf,wife,turbo and engine will thankyou for going with quality on this purchase. No for the name but the flow of the turbo/spool/heat/ fitment and overall engine performance.Traction is optional, so are zipties
92 Gtst/Silver bullet
Have you seen the newly designed manny with sced. 10 tubing....I would hardly consider that a poor flowing, prone to cracking manifold. The price reflects that too...the days of $200 chinese ornaments are over.
Jon.Last edited by Dragon Humper; 06-11-2014, 02:00 PM.Why don't you come over to MySpace and Twitter my Yahoo untill I Google all over your Facebook.
Dont waste your time on these chinese mani's. They boost creep terribly, are prone to crack and the fitment is usually garbage. Just spend the 1200 on a 6boost or get one built. Good luck!Raw Brokerage, Your RB specialists
R.I.D motorsports
"KRANKY" R32 #theroadto9's
Boost creep is a trifecta of factors...
A: waste gate vent pipe is too small or poorly positioned.
B: using a too small or poorly manufatured waste gate, always go overkill on size and buy quality
C: the turbo turbine housing is too stinking small because of this ridiculous disire to have a "response turbo"
Having my manifold out to do some maint. and looking at it overall, it aint that special. The wastegate is in the same spot as the CXR manifold and, although the pipe size is bigger, is about the same length. Granted the Trust T4 manifold is ment for a 800hp setup, hense the larger waste gate pipe. The CXR manny would be fine for a 600hp build, on an RB25. Just dont use a "600hp" turbo on it, use a manly snail and drive angry. The CXR manny has nice, large 1.75" runners too so it will make a ton of power on a 25...most likely to big for a 20.
If the turbine and wastegates are too small you will get boost creep with any manifold. Spiking is a whole other matter and usually the fault of the controller, not the manny or the gate (unless the gate is woefully too small because the turbine is too small).
This is the only one from them I would use, there is a $180 one but.....you know.
Jon.Last edited by Dragon Humper; 06-11-2014, 02:11 PM.Why don't you come over to MySpace and Twitter my Yahoo untill I Google all over your Facebook.
These were my thoughts as well.Originally posted by Dragon Humper View PostHave you seen the newly designed manny with sced. 10 tubing....I would hardly consider that a poor flowing, prone to cracking manifold. The price reflects that too...the days of $200 chinese ornaments are over.
I'm only running an RB20 guys, I'm not going to get anywhere close to 6 or 800hp.
Currently sitting at just over 300rwhp.
$1200-2000 on a manifold just seems excessive for a 400hp goal.1989 Skyline GTS-t Type M (Bee-R powered)
1991 BMW MK Motorsports 850i
1992 Widebody Mercedes-Benz 400E
1995 BMW 325i Convertible
1998 Toyota Avalon XLS (winter beater)
1993 BMW AC Schnitzer 320i (SOLD)
1992 Mercedes-Benz SL500 (SOLD)
Manifold cost is completely unrelated to hp goals.Originally posted by Bee-RSkyline View PostThese were my thoughts as well.
$1200-2000 on a manifold just seems excessive for a 400hp goal.oh hai!
check out hybrid performance manifold. Made in nz by a dude named Kam. He has a pretty good reputation on SAU. I have one his manifold. a topmount one with internal gate. Its not made of cheap stainless steel. its thick piping. so far im really satisfied with it. im running a td05 big 16G from kinugawa and it spool really fast on a rb20.!
Hybrid Performance is New Zealand & Australia leading suppliers for Aftermarket Performance Car Parts. We sell Turbo Manifolds, Exhaust Manifolds, Intake Manifolds, Turbochargers, Oil Cooler, Radiator Fans, Exhaust Heat Wrap, Adjustable Suspensions & more
edit. cost me 550$ shipped and took 3-4 weeks
Envoyé de mon SGH-I747M en utilisant TapatalkLast edited by frankydodo; 06-15-2014, 02:20 PM.
