So my MAF sensor is ******, i believe, and i'm getting a Z32 sensor to replace it. I have a power fc and i'm wondering how much timing i should pull with the terrible gas we have here in the southwest US.
If anyone is wondering about my MAF issue car occasionally wont rev above 2800-3000rpm or so, if it does it will work for a while and cut power and usually then stall out or it will work up until 3000rpm again. It used to do it rarely now it does it constantly and is only getting worse.
I want to be able to just install this powerfc and put the MAF in and test it but Iw ant to make sure i'm not super lean while doing it.
IDK how you measure octane in canada if it's RON or AKI.
Thanks for the help.
